Beijer E 1071 HMI
Benyamin
Mar 2012
Dallas
67
Hello,
Can somebody tell me how to Upload and Download program from Beijer 1071 Panel Operator/HMI to a CF Card directly without E-Designer, since I don't have one.
But if the E-Designer is a must to have, I will purchase it and please tell me the steps on how to Upload and Download.
Thank you very much in advance.
Best Regards,
Benyamin
If I remember correctly to back up you really need E-Designer, however, there is a way. power down the HMI, select dip switch 1 to on (I think) then re-boot, it will come up with a screen allowing upload/download from memory card. The card needs to be configured with directories & must be FAT32. I have never uploaded only downloaded so don't know if you can, the file will be a dat file so cannot be edited. the best way (assuming no password) is to use E-designer to upload the project then you can export it to a DAT file & put it onto a flash or USB card.
If I remember correctly, if you plug a clean card into the HMI & wait for a while it will configure the directories for you.
It can take a little while to recognize the card so be patient, it will briefly show a message. Also if it does not respond, try removing the card & re-insert.
Hello, Can somebody tell me how to backup/transfer program from Beijer 1071 Panel Operator/HMI to a CF Card and vise versa? Thank you. Benyamin
1,903
Hi! I have a E1071 from Beijer in use since 14 days. But now it does not start the project anymore. When i turn on the E1071, it writes: Status...
3,413
Hi all, First post here, I hope I'm putting it in the right spot! I have an ancient Beijer E910T which went down today. Given the proximity to...
306
I am looking to upgrade a CompactLogix on V18 to an L83E on V32 which is currently using a Beijer E1151. Does anyone know if the E1151 is directly...
645
Has anyone put together a combination of the Beijer iX Developer software and a Rexroth L54 controller over ethernet? Can't seem to get the...
552
