Bench testing high-power solid-state components: SCR's
IPSI John
Jun 2007
Alabama
33
Passively, an SCR behaves as virtually an open circuit to voltage pressure (attempted current flow) in either direction.
When a small current flows from the gate to the cathode, and there is positive voltage applied from the anode to the cathode, the SCR will latch on and be conductive in the anode to cathode direction like a diode, until a reverse bias current (attempted current flow from cathode to anode) switches the device off.
Whe have used these principals in testing the devices removed from the rest of the circuit to determine functionality and condition. Of course, a 'hockey-puck' SCR must be under the appropriate pressure for any test to be meaningful.
We fire the SCR on the gate circuit with 3 AA batteries in series, with a resistor to limit current.
To supply the positive voltage from anode to cathode and verify current flow when gated on, we use an analog meter on Rx10,000 setting, since it 'pushes' harder than a digital meter, but still is capable of only a limited current.
We then use the same analog meter to reverse bias the SCR to switch it off, and verify high resistance in the off direction.
We then **briefly** use a megger on the appropriate setting (500Vdc for a 480Vrms circuit, 250Vdc for a 240Vrms circuit) in the reverse bias direction first, then the forward direction to verify very little current leakage when the device is supposed to be non-conductive in the recifier circuit.
Although an SCR is a solid state device, none of these procedures apply a higher than rated voltage to the device, or inject more than a fraction of the rated current through the device when in actual operation. They are not fragile and secret 'black box' devices, but robust semi-conductors that obey Maxwell's and Hall's equations and are designed to operate in a harsh, industrial environment. The only diference in the bench-testing and the actual operating conditions is arguably the continuous amount of time a voltage is applied to the device.
Hi all, I have a AC current transducer that I want to bench test to ensure I am getting a 4-20mA output. I am using a AE001 unit. It is very...
130
Hi, i'm new to the forum, and new to PLC's I work for Siemens Rail systems in England, and our points system uses an Allen Bradley 1756-L61 B...
4,894
was trying to use Connected Components to connect to a 525 drive via usb with the face off but can't seem to connect to it. the screen lights up...
828
So I'm using CCW to program a panel view and this is not my first I have done many. My Problem is I get an error message that I have never seen...
511
How do you expand a branch in connected components workbench. Example i want to add an interlock around more than one contact. Most software you...
1,302
