benifits and limitations
wilbo12
Apr 2006
wigan
im having a few problems with the benfits and limitations of unitarysystems, rack mounted systems and modular systems. i believe the answer has something to do with the size of the systems and how many i/os they can handle. any additional information will be gratefully received
Ah, a new approach to the perennial HNC question.
If you were to perform a search of this site using the keywords "unitary", "rack mount" and "modulular", you would find a wealth of information on the subject. Be advised that some of the information is not for the faint of heart!
Furthermore, here are a few unsolicited comments on your writing skills. It is customary in standard English to capitalize the first word of each sentence. Contractions apply an apostrophe to indicate the position of deleted letters. The correct spelling of a word synonymous with "advantages" is "benefits"
They are merely typing errors, thanks for pointing them out though. I am too used too typing on word where my uncorrect grammar is either quickly corrected or pointed out.
I wouldn't rely on Word to pick up grammar mistakes, word wouldn't have picked up your mistakes in the following:-
Paul
P.S The site that Steve has linked to should answer all your questions regarding the PLC section of the HNC
Hey Wilbo
[rant]
Don't come here with your "...merely typing errors ..."! Get to grips with the keyboard - it's the main tool you'll use for the near future.
And if you do make it to the world of PLC programming, how do think your boss will feel when you dismiss the catastrophic errors in your code as "...merely typing errors...".
I'm not so sure they were typing errors - I'll bet you can type when you need to. I think they are English spelling and grammar errors. By your own admission, it's not that you accidentally hit the wrong key, you didn't know or didn't care what the right key was. Because Bill Gates had always been there to do his spelling for you. Take control - do your spelling, not Bill's. He gets it wrong too at times.
[/rant]
Ken
What are the benefits and limitations or different types of PLCs for specific applications????? Yes I am new to PLCs and need your help!
5,317
Hi All I have a little(BIG) problem that I am stuck with. I have a ES 200SP setup with a 1512SP CPU, two S110 drives and a AdvancedHMI screen...
2,394
Hello, Does anyone have any experience with Rockwell's Guardmaster 440-CR30 safety relays? As I understand it, you need to use Connected...
2,009
All, Thanks for reading this post and for any ideas and suggestions. As stated on one of my previous post, I am in the process of upgrading an...
5,250
Hi all, I am looking for the maximum number of write cycles to the eprom/eeprom/flash (?) of a Fraba/Posital absolute encoder. I have been...
1,649
