Bently Nevada 3500 Vibration Monitoring Panel I/O cards burnt - Probable Causes
rkumar14
May 2016
DELHI
Recently I am facing an issue with the BFP Bently Nevada 3500 VMS cabinet I/O card burn issue.
Below is the system description :
1) Individual/overall screens of the TST (Twisted Shielded Triad) cable are well insulated with plastic tape under & above screen.
2) Individual/overall screens are grounded at motor JB & VMS cabinet end.
3) Cards are operating at 230VAC control voltage.
4) 230VAC-UPS supply is grounded at both UPS & VMS cabinet end.
5) VMS cabinet is placed in a temperature controlled E-room.
6) No fuses are there on the I/O cards - nor bunched nor individual. However, supplier indicates "Intrinsically safe" signal wiring.
Can anyone please help in identifying probable reason behind this I/O card burn issue ?
Hi please need your help, can I install the Proximity Probe 21508-02-12-05-02 Bentley Nevada on the drive 1442-DR-5850 from Allen-Bradley using...
2,152
Hello friends; I have rslogix 5000 version 11, 13 and 16. But i have not the Bently nevada profile for rslogix 5000 for working on 1701 modules...
2,007
Does anyone have the BN 3300 modbus map? I want to connect the 3300 to a PLC5 using 1785KE card and RS232 cable but need the map and BTR/W setup.
5,790
Hy, we have a "Bently Nevada 7200 RV-R vibration monitor" which needs to be replaced by a new equivalent product. Can you help in selecting...
5,155
I have used this exact setup before (4 or 5 times) with no issues. Last successful implementation was a couple of years ago. Now, I have two...
2,457
