Bently Nevada 3300 modbus
gary wheaton
Nov 2009
California
Does anyone have the BN 3300 modbus map? I want to connect the 3300 to a PLC5 using 1785KE card and RS232 cable but need the map and BTR/W setup.
I don't beleive the 1785-KE module supports modbus protocol.
You may have to go with a "ProSoft" module. Or???
The 3300 literature I have specifically mentions serial communication to an AB using the 1785KE but does not elaborate.
Does your 3300 support DF1 protocol? If so then I believe your KE would work.
Well until someone corrects me I stand by my no modbus with your KE.
Yes, I saw that. But it doesn't provide a modbus map or DF1 addressing. I can't find one online and it's legacy. The 5 will have to poll it somehow. Suggestions? It's on a running compressor so I am limited in development flexibility. I'll have to shut it down to plug in the 1785, but I will be time constrained.
Have you tried calling GE? I have done modbus to an Intellution SCADA system. That was 20 years ago. Don't have the books anymore.
Hi please need your help, can I install the Proximity Probe 21508-02-12-05-02 Bentley Nevada on the drive 1442-DR-5850 from Allen-Bradley using...
2,151
Recently I am facing an issue with the BFP Bently Nevada 3500 VMS cabinet I/O card burn issue. Below is the system description : 1)...
2,783
Hello friends; I have rslogix 5000 version 11, 13 and 16. But i have not the Bently nevada profile for rslogix 5000 for working on 1701 modules...
2,006
Hy, we have a "Bently Nevada 7200 RV-R vibration monitor" which needs to be replaced by a new equivalent product. Can you help in selecting...
5,155
I have used this exact setup before (4 or 5 times) with no issues. Last successful implementation was a couple of years ago. Now, I have two...
2,456
