Best Method to bring modbus tag in contrologix 5000?
bobbys
Jun 2016
Fresno,CA
We have a chiller at our powerplant facility that we are communicating via MODBus RS484 using prosoft mnet card in our contrologix 5000 PLC. We have our communication already set and read write register tags in the plc. But the issue i have is one of the input register gives us diagnostic code and each code means something(for example if code value is 215 it means over voltage). There are over 100 codes and they all mean something. What would be the best way to convert these codes into an alarm description in the plc? Thanks in advance.
Do you just need to Display these on a screen or is there logic connected to some of these codes? if so the HMI can be set up to do different messages depending on different value in the same register depending on how you display your data to the operator... I know PV+ and ProFace do this anyways, im assuming many other brands and also Scada packages allow it as well
Just need a alarm to display on HMI, no logic behind it. We are using citect scada by Schneider electric. Thanks for the info i will look into that as well.
I've been using 5000 primarily. I've been able to based on prerequisite bits firing make an hourly production tag looking something like...
1,699
Good afternoon, I have multiple prox cables about 20 feet away from my electrical cabinet. I found these wiring blocks that I can mount close to...
1,821
I want to create a time stamp within my PLC when an event occurs and then read and display it as a string tag in my HMIs. I figured that someone...
1,661
Hi friends; We used rosemount transmitter of diffrent ranges. I want to know what is the best method to calibrate the transmitter. I mean Is it...
1,869
everyone i have a new slc 5/05 processor to configure . i have the choice of using bootp or calling my network admin to get settings for a...
2,014
