Best pneumatic cylinder w 4-20mA output
rguimond
Jul 2009
Escuminac
666
There seems to be plenty of different manufacturers of pneumatic cylinders with 4-20mA position indication. I need one with 2" bore, 24" stroke, 5/8" shaft, 85 PSI max operating pressure, single-ended, double-acting. Can anyone recommend a particular manufacturer for particular reason(s)?
I prefer MAC valves over Parker however you may find most pneumatic manufacturers have been bought out by Parker including Sempress
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
490
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
608
I am going to need to use HART multi-drop in order to handle a series of Vega Radar units. There are a lot of options and I'm wondering what...
255
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,144
Hello colleagues Anybody knows, what could be the best or a better option to bring with you when you are in service at factory to connect via...
264
