Best practise for oneshots in tia
Holmux
Oct 2013
Aalborg
279
Hi
I never got around to finding a good system for oneshots in siemens.
In AB i would normally use a DINT and point at the bit, this way I can see what is in use and which are free.
What is the best way to handle this in a Siemens plc (Tia 15.1) ?
/Flemming
Dont know what you mean with "Use a DINT" and "point at the bit".
Oneshots and the resulting output are usually used within the block where they are programmed, so simply define BOOLs within the FBs declaration that you use for this purpose.
If I have a variable 'name', then I declare 'name_ons' for the oneshot, and 'name_imp' for the resulting output.
Hi
/Flemming
Yes same, much easier.
For TIA, I just use the tag name followed by _ONS and create a tag table which houses them all.
I think he means he declares a DINT with name ONESHOTS, then uses ONESHOT.0 to ONESHOT.31 as his ONS bits.
Hi all
Thanks for your input
I was "hoping" there was something I overlooked, it is just nice to be able to see which oneshots are in use when you need to pick one :)
I will get the hang of the Siemens way
I basically do the same thing as Jesper, it's always made sense to me.
I also want to recommend that a big part of the best practice is using tags local to an FB as much as possible. ONS bits would need to be STATIC, not TEMP, tags.
If you really want to do things the AB way, you could use an array of bools, instead of a dint, but I wouldn't recommend it.
Hi all
To be clear: the advantage of using the suffix naming is you don't have to track which ones are in use, because they are all separate. There's not really much advantage to try to lump them all together, at least in Siemensland.
If you are so close on memory you need you need to pack your oneshots to save space, I think you'd probably save money by buying a bigger processor than spending the engineering hours trying to optimize things.
This is one of my gray areas in Siemens, I never really spend much time working on local tags, I would greate different tag lists or DB's, but all global.
It is on my bucket list :)
One tip is to set aside a bucketload of BOOLs so that you can add another oneshot at runtime without having to reload the either the shared DB or the instance-DB.
You will then have symbolic names such as #spare_ons_01, #spare_ons_02, .., #spare_imp_01, #spare_imp_02, .. etc. rather than meaningful symbolic names.
But it is worth setting aside some spare memory for online changes without having to change the declared data.
Also, memory is plentiful. 15-20 years ago one would constantly think about conserving memory. Nowadays one must think about writing code that is easy to understand and maintain.
I just make an array of bools to use.
You can point to bits in a DINT in TIA if you wish to keep a "standard" across platforms, up to you. Many ways to skin a cat
Local variables are fun and cleaner than global DBs. Less to keep track of. Fairly simple to learn. Temp variables exist only in the current block, Statics are stored between scans.
Looks like all the considerations have been covered by other posters.
For the sake of good habits, refer to the software as 'Portal' in shorthand, please don't call it 'TIA'.
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
500
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
613
I am going to need to use HART multi-drop in order to handle a series of Vega Radar units. There are a lot of options and I'm wondering what...
260
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,151
Hello colleagues Anybody knows, what could be the best or a better option to bring with you when you are in service at factory to connect via...
266
