jtashaffer
What do you guys use for a small compact installation? The setup is for just 1 input. A pulse off a scale and then send it to another plc.
What else is the BL20 doing? Why do you want to get away from the BL20? Is the BL20 currently exchanging data with the CompactLogix?The pulse output goes to a Truck BL20 Ethernet device with I/o attached. So is that acting as a slave to a main PLC? The main thing is to get away from the turck BL20.
I can't see the program that's there or replace it when it fails. I talk to tech support, and that was a dead end.I don't want to be out in the cold when it does. All three are tied to Important stuff.
