Best way of totalizing flow?
If you can set your meter up to output a pulse rather than rate then you won't have a rounding issue. Use the rate of change that the pulses are coming in at to derive flowrate.
Reading the instantaneous analog value will create errors.
No unfortunatley we can't set up the meter to output pulses. This is why we are trying to generate pulses with the PLC (S7-1200). I use the system clock of 10Hz to calculate the avarage value within 1 sec. So that the value is as close as possible. The flow rate is mostly steady and does not change that much.
I was thinking that if I were to use a faster clock, then the error would be less, no?
That's unfortunate. Yeah, looks like you are going to be doing the "area under the curve" calculation. So the faster, the better I suppose.
You are probably going to bang up against some limitations of the PLC that will make speeding things up past a certain point harmful/unproductive, so don't go crazy...
What is the make and model of your probe?
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
512
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
627
I am going to need to use HART multi-drop in order to handle a series of Vega Radar units. There are a lot of options and I'm wondering what...
265
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,159
Hello colleagues Anybody knows, what could be the best or a better option to bring with you when you are in service at factory to connect via...
269
