Best way to share rungs / routines?
JamesL
Mar 2014
Maine
18
Some folks are trying to help me with some converted PLC5 > ControlLogix errors. I have two routines of PLC5, and thus 2 routines of that converted to ControlLogix that would probably be helpful for them to see in the flesh.
What is the best/preferred way to share those?
Do I copy just those routines into new projects and send the projects?
Do I try the routines to PC5 files? (is that 'export?')
Can i share just the pertinent rungs?
Thanks, JamesL
One recommendation is to check that the people giving you assistance have the same version of ControlLogix that you do. If this is the case, you can send them the entire converted file ACD, in which case they can easily find the errors and assist you. If the errors are only in a few rungs, you may be better off just sending screen-shots to them of the rungs with the trouble.
Thank you much.
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
540
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
658
I am going to need to use HART multi-drop in order to handle a series of Vega Radar units. There are a lot of options and I'm wondering what...
278
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,191
Hello colleagues Anybody knows, what could be the best or a better option to bring with you when you are in service at factory to connect via...
277
