Best way to track power and free conveyor load bars?
stoveTop
Jan 2022
TN
Right now my system is using RFID tags on the load bars. Im trying to figure out how to implement error correction in this system. In the past, some of the stops have been damaged in process and give a bad input. Since the positions of the loadbars are not a consistent pattern, I cant simply shift all the indexes to correct when this happens. How could I error correct the loadbar position indexes in this situation?
Welcome to the forum.
A lot more information will be needed if an actual answer is desired. Now I could leave it at that and let you figure it out as a recursive joke, but I'm not that funny.
What environment (Logix? Siemens? Horner? make and model?)?
Describe and/or sketch the process.
Describe the model of the process implemented by the program code.
Post a PDF of the program code, if allowed, or at least the relevant section.
Describe the data layout (indexes to what?).
As already stated, more information is needed.
if there is only one power and free track, that should be ok to work with, but when you add spurs to the ling and bypass loops, that is another issue altogether.
james
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
498
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
611
I am going to need to use HART multi-drop in order to handle a series of Vega Radar units. There are a lot of options and I'm wondering what...
260
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,151
Hello colleagues Anybody knows, what could be the best or a better option to bring with you when you are in service at factory to connect via...
266
