We often use the Red Lion Graphite series as a PLC since it can easily handle the extra workload in scripts. So far it's worked out nicely. But now, needing to do PID control with less than 1s update rate. I know I can run this in the On Update section, which is supposedly run 10 times/second, but I don't want to just say each update is exactly 100 ms apart because I know that's not going to be the case. Is there any way to get more accurate time resolution on these? Without the control module....
