Bi-Coaxial Cable
allscott
Jul 2004
1,332
I am installing some sensors from a German manufacturer that is calling for "Bi-coaxial line symmetric. Z=100ohm, maximum length 1.5M High Temperature resistant. min. 230 grd.c"
Is this what we would refer to as TwinAxial cable in North America? The closest thing I can find is a Belden part #89207.
http://www.belden.com/techdatas/english/89207.pdf
Other than a slightly different temperature rating am I missing anything?
I have some blue hose here (Belden 9463) that I would like to try temporarily for testing. The only difference I see is a 78ohm rating instead of 100ohms as well as the temperature rating. I have honestly never quite understood the difference in impedance ratings of coax cable.
http://www.belden.com/techdatas/english/9463.pdf
Thoughts? The sensors I am hooking up are basically antennas that are picking up a magnetic field.
Impedance matching is important for efficient transfer of power. An impedance mismatch will cause some or all of the signal to be reflected back to the source. It may work, but with reduced sensitivity.
If only for the test you could try with 2 balun transformers. They are very useful when you want to transmit AV signal(75ohm coax) over twisted pair (100 ohm, pair of UTP or FTP)
But only for test. It is not a thing that I would let work anywhere else, but on my desk.
Sounds like they're requesting coaxial cable. TwinAxial cable is twisted pair. Can't say that I've ever encountered "bi-coaxial" cable. Nor have I encountered coax with 100 Ohm impedance.
According to Wiki (I know not always reliable) "Twinaxial is similar to coaxial but with two similar conductors". The Belden I listed has 100ohm rated impedance.
According to wikipedia, bi-axial and twin-axial are not the same.
edit: On the other hand, they said "bi-coaxial" which isnt listed in wikipedia.
Why dont you eliminate any doubt by asking the germans of an example of an acceptable cable ?
I guess that is what I will do. I was trying to save a bit of money by buying it locally. Absolutely everything in this system is exhobitantly priced. However the sensors are crucial to one of our major production lines so if their is any confusion it is probably best to just get it from them.
Interesting. That isn't coax. It's just twisted pair (twinaxial) cable with a braided shield. It's not really functionally different from AB blue hose.
And it doesn't appear to be any different then what I originally found.
AB blue hose is 78ohm characteristic impedance. That is the only difference I can find. The 89207 is 100ohm and high temperature rated.
I am considering using a "magnetic cable tie mount" like this one: https://www.grainger.com/product/MAG-MATE-Magnet-with-Zip-Tie-Holder-49M018 It...
101
I have an existing machine that we are adding some functionality. Currently every cable such as a cable going out to a 4-20 psi sensor for example...
255
Hello everybody, I believe that I will find experts here who have already solved a similar topic. I need to calculate the length of the...
353
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
134
Can anyone recommend a universal USB to IrDA cable for interfacing with power meters? I see a lot of generic units but hoping someone has...
65
