Bit OT -Wiring for an outdoor panel in Moscow
BryanG
Feb 2005
Manchester
1,987
I am going to be building a control panel for a machine that will be used outdoors in Moscow, average minimum temperature is -18C (0F), record low was -32C (-26F). What do you recommended in terms of wiring types for control panels in these temperatures. I have heating in the box but the system is run off a mobile generator and so will get cold at night. The components in the box are OK getting cold and I can put the system through a heating cycle in the morning but not if all the insulation fell off the cable overnight.
Bryan
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
284
A couple days ago I accidentally toggled an alwasyoff bit. The issue is it was set up as a single OTU on a rung, nothing else, and used as XICs...
226
Hi I have an old panel builder 32 that I’m replacing for a factory talk me hmi . In the plc for the old panel builder there is a coms bit for the...
75
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
159
I tried researching but I still don't quite get it. As far as I understood, it's used after a function is called in STL and then if the function...
145
