Bit That Indicate Switching In Slc 500
ckchew666
Aug 2003
Malaysia
591
I'm new in Hot-backup for SLC 500 using 1747-BSN. When there is a switching from primary to secondary, is there any bit that indicate this switchover? Pls advise...thanks.
Regards,
CK Chew
many factor can cause the switchover, no power from the primary rack, when primary is switched into program mode....etc..
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
284
A couple days ago I accidentally toggled an alwasyoff bit. The issue is it was set up as a single OTU on a rung, nothing else, and used as XICs...
227
Hi I have an old panel builder 32 that I’m replacing for a factory talk me hmi . In the plc for the old panel builder there is a coms bit for the...
75
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
159
I tried researching but I still don't quite get it. As far as I understood, it's used after a function is called in STL and then if the function...
145
