Blinking Indicator Light
mtmckenney
Apr 2015
Oregon
I am new to PLC's and I am working with an Automation Direct DL06 Koyo.
I need to make a LED indicator light start blinking after a process is complete before moving forward in the program. I would like for the light to blink until a button is pressed confirming the operator knows the process is complete. I have tried using a FOR/NEXT loop but it seems to only allow the light to blink for a specific number of times.
I appreciate any/all help and responses.
Thanks in advance!
Have the process end signal seal in a signal to start blinking, have the signal from the ack. button interrupt the sealed in signal
Same way you use a momentary Start button to start a process
Thanks for the quick response. I am still learning PLC programming and I'm not sure how to create the blinking signal or the seal in.
You said you already have it blinking some?
For the seal
Process end signal...........................Signal from button..................Created seal bit
--| |-----------------------------------------------|/|------------------------------------Coil---
Created seal bit.....|
Then use that created seal bit in the next rung
Created seal bit
--| |----------------blinking logic-----------------------LED
Sp4 1 sec off 1 sec on
Just so you know bit SP4 is a 1 sec blinker bit in DL 06
Then just use a latching circuit for the logic, remember this is PLC logic so don't think code, (look up - goto - jump ect.)
Thanks in advance!
I would also try to avoid using any for/next loops in ladder. It's fairly uncommon unless you need to do a loop operation very quickly.
--||------------------------------(SET)
end sig
--||------------------------------(out)
SP4****************************** light
--||------------------------------(RST)
Button
On the Red Lion Graphite panels there are three button/indicators at the bottom below the screen. The left-most of these is triangular shaped and...
2,177
Hello Software: RSLogix 5000 V.17 I am programming a conveyor system. Whenever a limit switch trips, the motor stops and I need the XIC...
12,767
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
233
I have a Micro820, yes I know they are hated. I have a brand new Micro820 that I programmed with a Micro SD Card. Once I got it programmed, I...
894
Hi, Have very basic knowledge of PLC's. Wondering if someone can point me in the right direction. Our assembly equipment is being run off of...
1,181
