Graphite - Blinking Alarm Indicator
Steve Etter
Apr 2002
Morristown, TN
965
On the Red Lion Graphite panels there are three button/indicators at the bottom below the screen. The left-most of these is triangular shaped and is, by default, used to indicate fault conditions. That is also the way I want to continue using it.
The problem I have is that it flashes any time anything is on the alarm page regardless of whether it's acknowledged, cleared, or active. I'd like to make it stop flashing without having to clear everything off of the page (we like to have it as a running record of what has happened).
Does anyone know a method for setting this so that only "active" alarms cause it to flash?
Ok. I did it a little differently and will simply have to train the operators to do things slightly differently than they are use to at this point.
I left the Alarm Viewer screen alone and created a second Event Viewer. On the page with the Alarm Viewer, I added a button labeled "HISTORY" that takes them to the page with the Event Viewer. Now they can accept and clear all alarms on the Alarm Viewer but still have record of what occured and when on their History page.
That is exactly what I do. I will often have a pop-up to clear the history with security restrictions on who can do it.
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
122
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
835
Following on from another thread, I just downloaded Crimson 3.2 and it now supports CR and Graphite HMIs. Time for a 'play' :-) It seems to have...
2,044
Been trying for a while to get a flowmeter with Modbus RS485 comms to talk to my Redlion Graphite HMI. Cable has been checked 3 times all good...
891
Our main testing HMI has 2 Ethernet sockets in it. One is setup on IP address 192.168.30.99 and communicates with our main PC network...
750
