Blinking Lights Using Slc 5/03
ckchew666
Aug 2003
Malaysia
591
Can anyone guide me how to create a blinking output in slc 5/03? One output is blinking 3 times per second, second output blinks 5 times per second.
I was doing it using 2 times, any better way? Thanks.
Regards,
CK Chew
what is duty of the cycle? do you need both speeds at the same time?
there are several ways to do it and yes it is possible to use
only one timer if that's what you prefer.
hesham said:
Thanks for the link, but those guys there discussing the topic in too advance way for this begineer. but found out another way doing this blinking from the link given, using one timer and one compare, let me try out first. Thanks.
Regards,
CK Chew
I don't need both speed at the same time, only one output will on at one time. The S4 flashing bit only apply to MLX? How about SLC 500, any flashing bit built in?
Regards,
CK Chew
Hello everyone. I have a bunch of e300s connected to a startix which is then going to the plc. All of them are showing their MS and NS lights...
4,548
I'm new at this, and want to write a simple ladder logic program that will make a light blink on and off for one second intervals when an input...
2,702
T
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
222
I have a Micro820, yes I know they are hated. I have a brand new Micro820 that I programmed with a Micro SD Card. Once I got it programmed, I...
891
Hi, Have very basic knowledge of PLC's. Wondering if someone can point me in the right direction. Our assembly equipment is being run off of...
1,176
