Block Move in SCL
CharlesM
Aug 2005
Arkansas
1,129
I have used SCL a couple of times but I have never called any functions from SCL. I am trying to do a SFC20 and I can't get the return value to work. The first one is without and I have tried "HERE" on the last two.
BLKMOV(SRCBLK := DB191// IN: ANY
,DSTBLK := DB192// OUT: ANY
); // INT
BLKMOV(SRCBLK := DB190// IN: ANY
,DSTBLK := DB191// OUT: ANY
HERE); // INT
BLKMOV(SRCBLK := DB200// IN: ANY
,DSTBLK := DB190// OUT: ANY
)HERE; // INT
Afternoon, I have a DB in TIA Portal V16 that is optimised. I cannot change this. There is an array inside that block which consists of 3000...
1,198
Hello, In Tia Portal I put a motion block called MC-MoveRelative from the Technology instruction. I choose an instance datablock and I want to...
1,463
Hello ladies an gents, I've always had a weakness of being too persistent; I often go way to long while knowing that all it would take to...
24
6,500
Hi, Ok bear with me, I have an Array of Real in a DB ranging from 0 to 10. In ladder I want when count pulse = 100 move count into Array 0...
2,094
Hello, I did a programming using MOVE block. However, whenever i press input. The MOVE block does not read the value assigned to transfer. Instead...
2,655
