Block transfer read
Lunu
Dec 2014
Sonora
26
So, I wanna control the speed value of a powerflex 700 from a panelview 600. The pv goes to a plc 5/40 and the plc goes to the powerflex 700. I can store a value in an integer in the plc, but I can't get it to the powerflex. Do I have to use instructions such as MOV? The BTR I used in the program matches the rack, group and module of the pv600, not the powerflex. The inputs and outputs are for the start and stop bits.
Unless you have Modbus or Ethernet hooked up between your PLC and the PowerFlex, then the easiest, surest way is to use a PLC Analog Output connected to an Analog Input on the Powerflex.
There are 2 possible Analog Input terminals (Numbers 1 to 4) on the Powerflex 700 I/0 Terminal Block, as shown on pages 1-16 and 1-17 in the PowerFlex 700 Adjustable Frequency AC Drive User Manual.
Good Evening , I need to convert a PLC 2/17 ( RS Logix 5 ) over to a CompactLogix 1769-L33ER . I took notice in the RS Logix 5 program that...
2,088
Hello, I am currently converting a project from PLC5 to ControlLogix. I have migrated the program from Logix5 to Logix5000 and any Block Transfer...
3,355
Hello, I am currently using a Control Logix with RSLogix 5000 trying to communicate with my 1794-ASB(Has a power supply, adapter, 16 point input...
6,044
so after a previous thread about the panelview 1200. I figured everything out that I needed to get working with it. I've got the RIO discrete...
1,580
Hello all, I couldn't find a solution through the search tool so hopefully someone out there can help me along. I'm working with a converted...
1,210
