Booting Panelview Plus to Configuration screen
bobwithdana
Dec 2003
california
239
Ocasionally if you cannot shutdown an application in a AB panelview plus and rebooting reloads the application it can be difficult to overcome.
One method is to plug in a USB keyboard and press [CTRL] {Windows} [ALT} and [SHIFT.
I have heard there may be others, Like tapping the screen while booting in 2 locations and or a way to boot using a USB thumb drive.
Does anyone know about this and can provide details?
Thanks in advance.
Bob
Restarting your PVP, you will see a white box in the left down corner of the screen; press it if you have a touch terminal (or press F1 if you have a keybord PVP) until you'll get the Configuration screen.
Hope this helps...
- [font=comic sans ms,sans-serif]fuzzy logic[/font]
If you have a tech connect contract you can view Knowledgebase ID 26037.
That technote includes a zipped file that can be copied to a USB drive and instructions to allow you to force the PV+ to the config screen.
I can't understand why it's not available to the general public.
really strange issue. The panelview(2711p-T10C22D9P) will try to load an application and get stuck on "Starting Alarms". If I reboot the...
1,453
U
I recently removed an AB pview 900 from service where it was working fine, after bringing it in to the office to find another use for it and clear...
1,734
Hi everyone. I got the endless "booting/connection" sequence on my Lenze 9400 HighLine. EZAEBK1001 Keypad is showing "question mark" while trying...
291
I have a Proface SP5000 series screen with the SP-5B41 brainbox on the back of it. The SP-5B41 went bad over a year ago and i finally got one in...
510
Hi all, I've been upgrading some machines recently which involves installing a 10" NB HMI, HUB and a CP1L-E to avail of the built-in ethernet...
1,707
