BootP - Windows 10
@drbitboy: just a regular hardwired connection, nothing special.
@hardaysknight: strangely, the keyence "ip setting tool" is what I downloaded in a pinch a couple months ago when I wasn't aware of the band-aid fix.
@drbitboy: just a regular hardwired connection, nothing special. ...
Huh. I there is only one IP interface active, then I am fairly certain that ICS cannot be the issue, which begs the question: what is using UDP port 67?
Can you please post the otuput of the command netstat -ano from a cmd.exe window? Also the output of the command ipconfig /all? Inquiring minds want to know.
I realize you have probably solved the problem and moved on, but it might be useful for anyone that finds this thread because they are having a similar problem.
But it is ICS, because when I kill those two services (host network service, and subsequently ICS), then I am able to use the new BootP.
Then I wonder what connection is being shared?
I did some more poking around.
Initially, the ICS process was not bound to UDP port :67, or any ports for that matter, according to [netstat -ano].
After I checked the box above and selected the WiFi network as the "private network connection," the ICS process (ID 3436) was connected to some apparently random ports on localhost:
UDP 0.0.0.0:49152 *:* 3436
UDP 127.0.0.1:49153 *:* 3436
Then, I turned on the Wi-Fi device and connected to my access point (IP address 192.168.1.137). At that point, the ICS process bound to several UDP ports, including :67 on IP address .137, which makes sense:
UDP 0.0.0.0:53 *:* 3436
UDP 0.0.0.0:51916 *:* 3436
UDP 0.0.0.0:51918 *:* 3436
UDP 0.0.0.0:64879 *:* 3436
UDP 192.168.137.1:67 *:* 3436
UDP 192.168.137.1:68 *:* 3436
UDP [::]:547 *:* 3436
UDP [::]:51917 *:* 3436
UDP [::]:51919 *:* 3436
UDP [::]:64880 *:* 3436
UDP [fe80::41e9:f0d3:c102:5439%14]:53 *:* 3436
And the Rockwell BootP-DHCP tool was not able to run because UDP port :67 was taken, even though I selected the non-Wi-Fi adapter at 192.168.1.193, although that is the same subnet*.
Then, I disconnected from the Wi-Fi access point, and even turned the Wi-Fi device off, so the .137 IP interface was not even up and running, and still ICS was listening on UDP port :67 and keeping the BootP-DHCP tool from connecting to the .193 IP interface.
Finally, I restarted Host Network Service and ICS, ICS got a new process ID (13132), and that new process went back to using similar ports to the original case:
UDP 0.0.0.0:53 *:* 13132
UDP 0.0.0.0:57438 *:* 13132
UDP 0.0.0.0:57439 *:* 13132
but not UDP port :67, and stayed that way even after I disabled the ICS in the adapter Properties=>Sharing dialog, and the BootP-DHCP tool was able to run again.
* I repeated the test after assigning the static IP 192.168.137.1 to the Wi-Fi on subnet 192.168.137.0/24, in order to use a different subnet. However, the results were the same i.e. the Rockwell BootP-DHCP Tool could not listen to UDP port :67 on the Ethernet 192.168.1.193 interface while ICS was sharing to private network 192.168.137.0/24 until the Wi-Fi 192.168.137.1 interface was disconnected and the ICS process restarted.
Can someone tell me if Host Network Service and Internet Connection Sharing (ICS) service are set to manual or automatic by default?
I just checked the BootP program today, and the program worked. I checked the status of those services and they aren't running, and both are set to Manual (Trigger) start up type. I don't remember if I changed the startup settings or not.
Also, can anyone with this issue tell me if they have any virtual machine programs installed (VMWare, Virtualbox, etc.)?
I never touched mine and they were both set to Manual (Trigger)
No VMs on this computer
Mine are [Manual(Trigger)] under the [Startup Type] column in the Services dialog, and I am fairly certain I have never changed them. That said, both are [Running] in the [Status] column, and this is immediately after a boot, which makes me wonder what the trigger was?
I think the [netstat -ano] output is a better diagnostic, of whether they will interfere with BootP, than the startup type or status values.
Edition Windows 10 Home
Version 21H1
Installed on 7/‎1/‎2020
OS Build 19043.1348
Experience Windows Feature Experience Pack 120.2212.3920.0
Last time I used BootP, I had to disable (in device manager) all other networking hardware. It's been a while, but I think I may have had to disable Bluetooth as well.
I just wonder is it just me or some one also have experienced the same problem - BootP does not recognize any active devices running BOOTP/DHCP...
3,982
Anyone having issues with getting the BOOTP.DHCP Server working properly in Windows 7? I can't seem to detect DHCP requests from devices. It...
19
33,313
Hello all, I have a 1732ES-IB16 Series A block that I have set the IP address on. I am unable to disable bootp using any method. I have tried...
338
I am not sure what i am doing wrong laptop ip 192.168.1.233 with subnet mask 255.255.255.0 micro820 ip unknown 1) i connected a micro820 and my...
3,893
Hello. I'm using bootp to set an ip address for a 1747L551 processor. The bootp program immediately sees the mac id and I am able to enter an...
1,185
