Bosch Rexroth Indramat
Ron's information is correct.
Just to expand on this a little, as Ron said Syntop works with the SYNAX (SYNchronized AXes) firmware for the PPC and CLC motion controllers. SYNAX allows you to do electronic gearing, registration and simple moves on axes sychronixed either to a virtual master or to one another. SYNAX made it's name in shaftless printing press applications. Syntop is basically a fill-in-the-blanks format to allow easy design and commissioning of synchronized web lines. Syntop will only work with the PPC or CLC controllers, not with individual drives.
Drivetop allows direct connection to the Indramat servo drives, including the Indradrive, as Ron mentioned, as well as the Ecodrive3 and, I belive, the DIAX04 drives. Drivetop will only allow adjustment of drive-based function. So it won't allow you to edit any of the SYNAX stuff.
These are two different software packages for two different platforms.
Keith
DriveTop works on DIAX03, DIAX04, and of course, the new IndraDrives.
You can think of Synax another way. If it has to do with the SERCOS ring, you need Synax. If its just drive parameters, DriveTop. The kicker is that _almost_ anything you can do with DriveTop, you can do with Synax.
Inside a PPC, there's also the possibility of one of two different programs running, the ML (Motion Logic), or M(I don't remember) for the SYNAX I/O mapper.
I/O mapper has very limited logic, and basically connects drive status and command bits to other bits.
Motion Logic is a verson of CoDeSys programming, to the IEC 61131 standard, and very powerful.
One other thing....each drive has a firmware module, matched to the application, and the drive configuration.
Each PPC also has a firmware module, depending on the industry, and choice of Motion Logic or Mapper (you can't have both).
Does anyone know of a similar site for servo drives? Or does anyone know enough about Indramat ECODRIVE03 SMT-02VRS, to tackle a few questions?
6,204
Good Day I trust you are well, I am struggling to find someone that is familiar with the software "bosch Rexroth Indralogic Engeneering" I am...
1,534
Hello . I have some kind of problem with loading program into CLM 1.4. I have working controler which has first symptoms of coming failure...
1,275
Hi guys, My name is Kevin, and I'm doing internship right now. I need to make an universal denester, filler and lidder. Right now I'm designing...
4,346
Dear Sirs, in my current application, I am using a Bosch Rexroth L20 PLC communicating with Hightec PWS-6A00T-N HMI, but in the configuration of...
4,138
