Hi all,
I have a Boy machine 15S that I converted a couple of years ago.
You only need a DIO PLC for the job. You really do not need a manual to run the machine.
The only odd thing I encountered is that there was no retraction solenoid for the screw. The act of the screw turning and loading the barrel retracts the screw. This means you cannot run it dry. I am not an expert in these machines but I use them a lot. I kept the three black flip flop switches and I added some buttons to manually control the machine. All buttons are soft. I need to load the barrel to start the process. I can in theory run the machine using only manual buttons but I have not tried it.
With the barrel loaded, my processes is as follows.
Close the mold .
Use the HP clamp if needed for a larger part.
Make sure the carriage has the nozzle driven in the part.
Inject resin for a the required number of seconds. You are also allowing the resin to solidify.
Use one of the switches to make sure you do not run the screw too far forward.
Turn the screw until a limit switch is reached.
I leave the nozzle in sprue bushing.
Open the mold.
Eject the part.
Detect part drop.
Repeat as needed.
The machine has ran all day without needing an attendant.
I have also used the HP clamp to coin a part.
When I retrofitted, I first removed the timer and then all of the buttons. I fabricated a new console plate with about a dozen buttons.
Leave the other side of the electrical rail alone.
After I found and connected the solenoids, I added a relay for the pump.
I set my ohm meter to beep mode and each limit switch was found and added to the PLC.
There are a few limit switches that are coupled together or are normally the opposite.
I added digital temperature controllers.
I never added a locking kill switch but I have a lot of redundancy in the software. Oops, I just walked over to the 15S and there is hard kill switch for the motor only.
I also run the mold clamp slow to prevent slamming the mold shut.
The machine is slow and old.
I run the cooling water through a closed loop radiator outside (a gutted heat pump using the coils and fan) and I also use a box fan across the tank in warm conditions.
I do not know how hot the hydraulics should get but I can always hold my hand on the tank.
I am sure that I may be doing things wrong but I am making parts. All of my parts have threads so I use a motor to unscrew the parts. I hope this helps.
