BradCommunication Profibus SST-PB3-CLX-RLL clard in Controllogix
wilsonzhu
Jan 2008
vancouver
278
We are planning to use Bradcommunication's SST-PB3-CLX-Rll profibus in Controllogix platform, I have a look at the menual and tested in the office, It seems very good.One question is totally there are four pages of profibus I/O, does I need to write some ladder logic in controllogix to switch between pages(0-3) to reflect I/O in controllogix and I/O in profibus network if I/O is exceeding 250 words? if you have used Prosoft technology's profibus master card MVI56-PDPMVI, Compare this two cards, which one is better? Thanks.
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
189
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
87
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
109
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
322
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
318
