Brand New PLC Learner
androcci
Dec 2018
New Jersey
Hello everybody I am new to the site and new to PLC programming.
I would like to know a couple of questions. I am using a function block flow task template on RSlogix5000 v.20.04
first I made my PIDE work but when i change the set point higher than the PV the CV goes way down and after a good amount of time it slowly goes up and if i increase the PV higher it sinks again. is like it seems my PV ramping up and CV closes but i would like to not act so far ahead cuz is so far from the SP.
sp=80 PV=40
also i want to characterize a table of x and y values to produce a curve and the output it to an air damper, which block does that? is that under the math section? I have browsed through all the options I cant seem to find the magic block with a blank x and y table.
if you could send me some files with PIDE working and characterization would be much appreciated!! thank you!
For the first part of your question: you need to try different values of P, I and D and see which work best (PID tuning).
For the second part: not sure exactly what you are trying to do but I would look into the CPT or FGEN instructions.
Yes, I see. I found the FGEN block to be the one i am looking for. I just dont know how to take any input into X1 which could be anywhere from (0-100%)
and then output something from 0-100%.
I want to characterize a flow signal. does anybody can give me an example? on how to make the block work? i get a big red X in a circle on my block. Thank you!
I got rid of the crossed red circle by making REAL[11] for x1 and y1. i have enabled in and out. i have an analog flow coming in but nothing coming out
I changed instructFault, XY1sizeInv, XY2SizeInv to zero
i got it working!!. i didnt know that XY size was at 0 and it is suppose to be the sam size of the array which in my case is 11. Thank you anyways!!
Hello! My name is Luke and I started training about a month ago at a company to repair and remanufacture PLCs. I've done a lot of training and...
1,628
Hi, Does anybody have experience with Ethernet/IP-CIP Safety comms between 2 different brands of PLC's I have a project with 1 Safety Allen...
3,579
I am developing a PLC. The IDE for my PLC will be VS Code. I want my PLC to support IEC-61131-3 but only one language with is ST. Actually I...
28
7,988
Hi, I'm starting a simple project and I need to choose a PLC. It would need to actuate over some relay outputs (6) an HMI scada type screen...
2,763
:yeah:Hi all, We are a small company involved in water and wastewater treatment and have been feeling the need to "upgrade" our standard...
1,936
