PLC brand / modules selection
jsolo
Jul 2017
Ireland
Hi, I'm starting a simple project and I need to choose a PLC.
It would need to actuate over some relay outputs (6) an HMI scada type screen interface, but the key feature is that we need some data (recorded states and the date of them) out of the PLC, by usb, sd card or even better sending it through Ethernet to the cloud or to another local device in the network.
Any ideas?
Thank you
Do you have software for a certain brand? More often than not, the major issue with selecting a platform is whether or not you have the required software for programming.
I am partial to Siemens, so I would say that a S7-1200 could do what you want and be a Web Server HMI (https://www.dmcinfo.com/latest-thin...m-getting-started-to-html5-user-defined-pages). I never did connect a PLC directly to the cloud, but I believe Siemens had an IOT platform on purpose for this... IOT2000, perhaps?
Beckhoff most likely has the capability to upload stuff to a normal server in the internet, but it's not something I have experience with. Perhaps looking on their website to see if there is a package that can achieve this is a way to go. Beckhoff can also run an HMI and PLC in the same device and some models have a USB port, so it may be just what you're after.
Maple System (Hmi) then use MQTT to publish data to CLOUD. Now you can subscribe to the cloud and store that data into a SQL database to do with as you please.
This could be done with a cost of ($299.00-Hmi) and ($250.00-PLC-Allen Bradley Micro820).
I agree with Maple HMI. Is the AB 800 series the one that takes forever to download? Over 30 seconds?
I would suggest something from Automation Direct. The new BRX series looks good, but I haven't tried one yet.
Hi jsolo,
I would choose a Codesys V3 base PLC. For Example a WAGO PFC100 or PFC200.
If you are looking for a solution as a Cloud HMI, have a look at AnyViz. It is a cloud portal for controlling PLCs remotely.
Regards
Hello! My name is Luke and I started training about a month ago at a company to repair and remanufacture PLCs. I've done a lot of training and...
1,627
Hi, Does anybody have experience with Ethernet/IP-CIP Safety comms between 2 different brands of PLC's I have a project with 1 Safety Allen...
3,579
I am developing a PLC. The IDE for my PLC will be VS Code. I want my PLC to support IEC-61131-3 but only one language with is ST. Actually I...
28
7,986
Hello everybody I am new to the site and new to PLC programming. I would like to know a couple of questions. I am using a function block flow...
1,476
:yeah:Hi all, We are a small company involved in water and wastewater treatment and have been feeling the need to "upgrade" our standard...
1,935
