Bristol Babcock BSAP Communication Problem
jphillips
Jan 2009
Mandeville
I have a Bristol Babcock (BB) 3330 CPU with a BB Communication Board. Port A on the communication board is set up as a custom port for modbus communication back to the HMI (National Instruments Lookout)software computer and port B is set up for BSAP communication. Recently, a problem has occurred with the communication involving the BSAP port. When I look at the modbus communication statistics in the HMI software we are getting a lot of CRC errors when both ports are connected. However, if I unplug the cable from the BSAP port the communications are excellent (CRC errors = 0). I have replaced the cable going to the BSAP port and swapped out communication boards but the CRC errors still exist.
Does anyone have any idea what might be causing the CRC errors and what other methods I can try to resolve the issue?
Thanks for any response.
Jason Phillips
SCADA Manager
Hi Guys I am in urgent need to get some technical information on 3310 and BSAP global addressing stuff. Things like how can we connect...
2,898
Yes you read that right. I've got a lone Bristol Babcock 3330 out in our system that I need to replace. The plan is to go to an Allen Bradley...
1,552
Hi again everyone, I'm running into a ton of bristol plcs out in the field at my current position. My boss and I were discussing a few of us...
1,894
I am integrating a BB Controlwave processor with newer AB L5K platform, and need to make the 2 communicate reliably together. The Bristol...
3,186
Hi ppl, I might land a job where they are using Bristol babcock PLCs. I've never heard of them. I have been in the industry for only 2-3yrs. Any...
2,071
