Bristol to Compactlogix
Was hoping to get away from that
Was hoping to get away from that. I can do it with a Prosoft card, or use a Productivity 1000 as a converter. But that adds a piece of hardware and failure point.
Thanks if we come up with anything I will post for others to use.
Cowboy
Might check with RedLion.
I believe the data station handles BRAP.
In my experience, they are extremely easy to configure.
Yep it does. I have one of those as well as the prosoft unit. I also have a Molex card for compact logix. All three work was just hoping to find a way without adding hardware.
Guys
Cowboy
They fail that seldom, that shouldn't even be a consideration.
I have had the Red Lion lock up twice in the middle of the night, we had to come in for it. So yes it is a consideration. Also it is another piece of software for my team to learn and support. We are going to be replacing 60 or so remote Bristol PLC with AB over the next 5-7 years. Once we put in our new radio rings and Data Concentraters it is not a problem with kep ware.
I have a Bristol Network 3000 3335 communicating with a controllogix using modbus RTU, and a prosoft inrax modbus card.They are only 10 meters or so appart and works well.
I'm installing an HMI for an existing RTU. I have a spare control wave I want to dump the program into to test it before I go to site, however...
271
Does someone know what is the function V_ATTRIB_GET? I can't any information about it anywhere in the internet.
378
I am looking for someone that may have copy of ControlWave Designer or OpenBSI v5.9. I am looking to do some testing and from what I read there is...
810
I am looking for someone that may have copy of ControlWave Designer or OpenBSI v5.9. I am looking to do some testing and from what I read there...
809
Yes you read that right. I've got a lone Bristol Babcock 3330 out in our system that I need to replace. The plan is to go to an Allen Bradley...
1,558
