BRX 1C LED turning on RED
lesmar96
May 2017
PA
520
Good day,
I am using a BRX Automation Direct PLC for the first time on a project. While working on the project, the led under 1C (output common) started turning red when some of the transistor outputs turn on. And it also seems those outputs do not turn on (though their LED is on) when that 1C LED turns red.
I have been going through the hardware manual, but I haven't found what it is supposed to mean when this LED goes red. It normally hasn't been turning on at all. It doesn't show up as any hardware issues in Do-More.
Can someone direct me? Thanks.
From the manual in a footnoote about the outputs:
2. When the high-speed outputs are in an overcurrent situation, the Common terminal Red LED is on. The output LEDs will remain operational even though the output circuitry is turned off and no power is flowing. This condition is not reported to the CPU.
Try posting at https://forum.hosteng.com/, you should have an answer quickly.
Oh, nice! I didn't know about that forum.
So I do not have my outputs configured as high-speed, but apparently the red LED probably means the same thing for standard configuration. I have traced it down to a certain output. When that output (Y9), the 1C LED turns red. If I disconnect the wire from that output, it doesn't do it.
I have a C-More EA9-T8CL that I'm trying to connect to a BRX DM1E-M PLC via ethernet. I have the IP addresses set as static 169.254.1.0 (PLC) and...
3,224
I am having difficulty getting online with an Automation Direct BRX processor. Model number is BX-DM1E-M. Have set an IP address through USB...
1,772
So I started a thread at the AD forum... https://community.automationdirect.com/s/question/0D53u00002O4jbSCAR/brx-sd-card-storing-v0v4095 And I...
1,717
Hello Everyone, I have a project that I have been working with a customer on and need some help/ideas, its a large project but small parts, one...
17
5,925
I had a project possibility fall in my lap yesterday, and I spent some time trying to figure out the mechanics of sending a couple values between...
4,865
