KEN_KACEL
I am looking for a formula to give me BTUs based on flow and temperature difference through a heat exchanger. The application is a variable speed pump which will control flow through a heat exchanger liquid-to-air with circulating fan and make sure the correct number of BTUs are removed from the liquid.
The flow will be controled through a PID and based on the variable in BTUs.
I am looking for some control on an outside wood burner (hydronic)
