Build a graphic with Syswin 3.4 ?
Queen
Jan 2005
Surabaya
Hi all,
I use a omron cqm1h cpu21 with the Syswin 3.4 software. From analog input and analog output, i want to make a graphics the input voltage in Syswin 3.4. Can Syswin 3.4 build a graphics?
thanks
On the face of it, no.
What do you mean by graphic?
Syswin is only designed to allow ladder or mnemeonic (SL) programming. SCADA systems or HMIs are normally used for graphics.
Thanks Bob.
I use pid control to control inverted pendulum.
I want to monitor the voltage input from the potensiometer & output from the DA021. I want represent that voltage in graphics so i can define their time delay, rise time, setling time, overshot and error steady state.
Sounds like you need CX-Server Lite and VB into Excel. Check in the downlaod section. There are some examples there.
Hello everybody! I am now testing a system that provides me an analogue input (a force measuring load cell). For better understanding the...
3,211
84
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
397
I'm looking for some clarification if anyone here is familiar with UL698a panels. Panel is out of zone/class'd area. with thermocouples extending...
120
Hey guys, last week I posted part 1 of a series of OPC UA articles in Node-RED. That article covered some important concepts of OPC UA and how...
3,928
