UL698a Class I Div 2 Question on build?
einnh
Mar 2014
New England
275
I'm looking for some clarification if anyone here is familiar with UL698a panels.
Panel is out of zone/class'd area. with thermocouples extending into Cl.1.div2. This would generally make a portion of the UL508a panel fall under UL698a. It looks like on previous, similar, panels Class I Div 2 barriers were installed with the required spacing around them and the panels were listed as 698a. for signals extending into Class I Div 2.
But here is my confusion...
UL698a does not list Class I Div 2 in it, only Class 1 Div 1. But UL508a says to follow 698a. I asked our field rep. and was told basically we can build it to Class I Div 1 standards and use it for Class 1 Div 2, or procedure list it for class 1 Div 2 ($$). Is this accurate?
As far as building it, can we use Class I Div 2 barriers? Or do we have to use class 1 Div 1? With the appropriate spacing and separations, is this fine? I don't know why Div 2 is causing so much confusion.
Thanks.
Edit, I've been on here for 10 years it looks like! 🎂
We normally ground the -24VDC side of a control systems power supply. What are you folks thoughts about grounding the -24VDC side of a class 2...
110
Hi, im facing an issue to change the alarm level into another state in the alarm class configuration in Cimplicity. Im trying to change the...
470
Hi - I am searching for an M12 panel receptacles to use for ethernet connections. I see lots of M12 cables that are ATEX / C1D2 rated but nothing...
981
I'm working on getting a handful of devices hooked up to an EWEB card on an Allen-Bradley 1756 PLC using the Ethernet/IP socket interface, and...
2,043
Can someone please recommend a signal light tower that can be used in a Class 1 Div 2 Classified area? Explosive gasses can be present under...
1,742
