sparky64
I have a 3 phase 3kw motor that is rated at 6.5 amps flc, the motor is controlled by a power flex 70 drive. The drive is protected by a Bulletin 140 mpcb. I have set the parameter for flc in the drive to 6.5 amps, but in order to have discrimination between the drive and the mpcb, what should i set the current trip on the mpcb to, should it be set to the inrush current of the drive, and if so, is there a rule of thumb, or do i have to use the inrush current formula for each seperate drive.
thanks in advance
Sparky
thanks in advance
Sparky
