Bulletin 160 controller to PowerFlex 70
nomalas
Nov 2012
NJ
Hi, everyone.
I'm new at this forum and I don't have much experience with PLC's, VFD's, DeviceNet's, etc. At my work we have DeviceNet network with three 160SSC Bulletin controllers. One of them failed and as you probably know these type of controllers are obsolete.
In a few other machines with DeviceNet network we have installed PowerFlex 70's and we have them in stock, so I thought maybe we could use it.
My question is: Is it possible to convert AB Bulletin 160 to PowerFlex 70.
I've read this http://www.ab.com/support/abdrives/conversion/160_pf4class_convert.pdf
but this is only about conversion Bulletin 160 to PowerFlex 4/4M/40
If the conversion is possible what will I have to do? Will changing drive's and DeviceNet parameters be enough or I will have to make additional changes in a PLC program.
Thank you
Welcome to the Forum!
Yes, it is certainly possible, but probably more involved than the PF40 conversion
A lot of the information will be applicable to the PF70 Conversion, but there are differences between how the PF40 and PF70 work.
You will have to make changes to the PLC Program. One thing that comes to mind, is the Speed Command Scaling is different on the PF70.
PF70 Manual:
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/20a-um001_-en-p.pdf
20-COMM-D Manual:
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/20comm-um002_-en-p.pdf
Stu....
what are some of the most common causes for an Eeprom fault to occur on a AB Bulletin 160.
1,559
good morning all I have several red lion da30d using crimson 3.0 on the controls network in the plant. I am thinking about getting the AB power...
2,169
Has anyone used the 1771 wiring arm conversion hardware to convert to 1756 RTBs ? Is it as simple as it sounds? Is there anything to be wary of...
2,269
I need a crash course in this Bulletin 22-XCOMM-DC-BASE DSI Communications Kit communicating with powerflex drives and sending control "messages"...
3,274
Hello There,I am trying to locate a Allen-Bradely manual. Please help. I tried searching for one,no luck.
2,733
