Button visibility on PV 1000 Plus
irinjia
Jun 2017
Ireland
Hi All,
I have four HMI buttons.
When one of these buttons is pressed I would like the other 3 to disappear.
I can make it work if Button 1 is pressed, then Button 2 will disappear but I need to add the 3 expressions to each HMI button.
(Working on Button 2 Visibility)
This is what I entered to start with:
• If{[topsidecoater]_HMI_b_LoopSelectionPB[0]} =0 then 1 else 0
How do I add if button 3 and 4 are pressed into this same expression.
Please see a word document attached for clarity.
Thanks.
irinjia
Button 1 Invisible
({[PLC_Topic]PB_2_Pressed} OR {[PLC_Topic]PB_3_Pressed} OR {[PLC_Topic]PB_4_Pressed})
Button 2 Invisible
({[PLC_Topic]PB_1_Pressed} OR {[PLC_Topic]PB_3_Pressed} OR {[PLC_Topic]PB_4_Pressed})
Button 3 Invisible
({[PLC_Topic]PB_1_Pressed} OR {[PLC_Topic]PB_2_Pressed} OR {[PLC_Topic]PB_4_Pressed})
Button 4 Invisible
({[PLC_Topic]PB_1_Pressed} OR {[PLC_Topic]PB_2_Pressed} OR {[PLC_Topic]PB_3_Pressed})
Thanks chopin,
Just testing it now and its works great.
Thanks for your help.
Regards,
irinjia
Hello, hope yall are doing well. I have a HMI program where I need to add a "GoToDisplay" button, so when this button is pressed, it goes to a...
898
I have 3 groups of users under security settings. i want a button to be visible when group1 or group3 logged in, and invisible when group2 is...
1,276
Hi Guys, I am working on the main Log In / Off display for my HMI project, and I am having an issue with the visibility of a button with the...
1,872
Had a couple questions about the visibility tag because the help doesn't provide much info at all about it. 1) Does it hide the button so that...
7,147
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
143
