C More 10" and bitmaps
dginbuffalo
Dec 2010
Buffalo,NY
630
I'd like to pull in an Autocad P&ID to one of my C-more screens. It appears a bitmap is all that is allowed. First time working with one of these-What's the best way to bring it in and size it for clarity?
The few times I've had to do something like this, I've just used the 'trial-and-error' method. I do a printscreen (ALT-PRTSCN) in AutoCAD, then open it up in a with an image viewer. My favorite is IrfanView (LINK), but MS Paint will suffice. Crop it and save it as a bitmap, and see what it looks like on the screen. Then zoom in or out in AutoCAD to achieve the size you need and repeat.
-Eric
Once in your favorite bitmap editor, you should be able to scale it to the pixel size of the intended frame in the HMI software. Thanks for the Link Eric, I have been a fan of paint.net for years, but that one looks very cool...
Try Gadwin Printsreen.
http://www.gadwin.com/printscreen/
It's print screen on 'roids. I use it all the time for work instructions for my operators.
You might also look into PDF to bitmap converters. They are all over - just Google. Print your AutCAD as a PDF, and then convert it to a bitmap.
-rpoet
Hello everyone, Wondering if anybody can help me with this: I have a CompactLogix processor running a little robot cell. Every 200 cycles...
184
Hello, i need to use P_Intlk and feed the Status interlock OK bit to a P_DOut block. However, there's 17 interlocks for this output. How can I...
135
Hi everyone, recently i worked with a cmore panel and have the question that how can clear alarm list whit remote form,right now only can with...
134
Hello, friends, I am trying to upgrade a system that uses an Onrom incremental encoder (E6B2-CWZ6C) connected to a Danfoss VFD (FC360), but now...
295
Hello Friends I have took the sample program from AB webpage and modified, but I can only send 127 chars...
208
