C-More programming and Recipe number entries.
Tharon
Jan 2007
Other
1,430
I've built a few programs with Recipe databases using the Cmore programming software and some EA7-T6C screens.
When I do standard numeric entry buttons I can limit the value they are allowed to enter in the settings, and the pop up keyboard will display the allowed min/max.
But when I have a numeric value inside a recipe, I cannot find where to limit this entry. Right now I use my PLC to make sure the value is within range when they load the recipe, but they can still edit/save values outside the allowed range in the recipe. And when they open the keyboard to put values in it shows huge min/max values, which are inaccurate for the process.
I've looked through the help files, settings, even tried making custom keyboards and trying to find a place to change which keyboard is loaded when they select that entry. But so far nothing.
I'm using Cmore Programming Software 2.75. I know it's not the latest but so far the release notes I've read have not mentioned this feature.
Unfortunately there is not a way to limit the settings in the recipe object. We have it on our to do list, but I do not have a time frame for when it will be accomplished.
Thanks,
Read through a bunch of topics over at the AutomationDirect forums over the weekend and found a few topics on it. A couple suggested using an event to popup a warning as the operator loaded recipes with values outside the range. Seems doable for now.
Software will not let me import my tags. I am trying to import the tags from my PLC program into my HMI project, but the software just keeps...
2,131
I am trying to delete some tags in the tag database but I keep getting error saying I cannot because the tags are associated with objects. How can...
2,592
Dear sir. i have one Automation Direct hmi, if you have the CMORE Programming software,i will send you .eap file in email, can you please...
2,446
Hey guys I was asked to install a simple HMI and PLC in a tumbling machine. I only need a couple of editable timers. I can easily create a program...
3,444
I just purchased the c-more programming software ver 2.77 to program my new 15 in full color HMI. I am new and still learning the ins and outs...
2,275
