C-More Recipe Example
gbradley
Apr 2002
Corona, Ca.
1,637
Does anyone have a C-More Recipe example that they would like to share?
Or point me in the direction of an example online.
I've watched a couple of videos, but I do a little bit better if I have a hands on example that I can modify and play around with.
The PanelType that I am using is EA9-T7CL-R, but anything I can open with the C-more programming Software version 6.72 is good.
I am using a Cmore Micro panel for my project but the recipe function is the same. Two video examples are here
https://youtu.be/6euiwFqSD0g?t=2012
https://youtu.be/XRoyLN8NaxE?t=324
The left side of the display is my blocks on the track with an offset in percent for throttle output for the track. When you add a recipe button you define which tags to modify and the value to move to it. It can be a constant value (such as an integer number) or another tag. (PLC data) My screenshot isn't accurate to the video as I am not at the computer I am using to develop the project so I just threw a quick button on the screen.
In my video, when I press one of the recipe buttons (i defined 4) the integer values for the throttle offsets are changed and shown on screen to the left. I also do have the ability to change an individual offset via the button that displays the value to the left.
Mike
I'm having serious trouble trying to get the recipe function to work. I'm using an EA9-15" with a Productivity 2000 plc. My "recipe" consists of...
3,856
Hopefully someone has had more experience in this than I have. I was tasked with making a recipe function for a project. I've done so based on...
2,699
I've built a few programs with Recipe databases using the Cmore programming software and some EA7-T6C screens. When I do standard numeric entry...
2,021
How can I name the label of a new recipe without connecting cable and downloading program? Let say the customer creates a new recipe using the 10...
4,781
Hello, i need to use P_Intlk and feed the Status interlock OK bit to a P_DOut block. However, there's 17 interlocks for this output. How can I...
110
