c-more to ml1400 ch1
hackj0632
Jul 2009
wi
33
I am trying to connect a ml1400 to an automation direct c-more throgh ethernet ip. the c-more is displaying an error "plc-498 0x100000"
PLC-498 Error code 0xaaaaaaaa returned from PLC
Allen-Bradley EtherNET/IP specific. Service Packet Error.
See the explanation for error code PLC-498 proceeding the Allen-​
Bradley EtherNet/IP error code tables.
0x100000 Device state conflict: The device's current mode/state prohibits the execution of the requested service.
an help to resolve this issue would be great thanks
If you read a little further into the C-more help file and you'll find this:
0x100000, Illegal command or format. Typical error received from PLC when addressed requested to the PLC does not exist. Usually occurs if memory map has not been expanded in PLC to the range requested from panel.
i am having the same issue now. i just upgraded a program from a slc 5/04 to a slc 5/05. after i finally got the program to work and the processor to stop faulting the hmi started to display error "plc 498 error code 0x100000 returned from plc on service." i've called automation direct and they dont have any idea what could be causing the error. if anyone can help, i'd appreciate it.
respectfully,
MAC P.
You don't have your memory map expanded in the PLC. I do it all the time when connecting C-more to an AB PLC. Usually I pull the project up in RS Logix but forget the download it (until after I see the error).
You can go to the System Screen in C-more and look at the error tab and it will usually tell you exactly which memory address has not been expanded.
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
523
Hi friends, I have some questions here. I hope someone can give me good answers soon. 1. What does the"processor node" work for? If there are 3...
1,741
Has anyone used the ML1400 with a C-more touch screen? I can not get them to communicate through ethernet connection. i was told by a rockwell rep...
2,282
Hello, i need to use P_Intlk and feed the Status interlock OK bit to a P_DOut block. However, there's 17 interlocks for this output. How can I...
130
Hi everyone, recently i worked with a cmore panel and have the question that how can clear alarm list whit remote form,right now only can with...
120
