c200h problem
dis
May 2009
shanghai
31
the plc is c200h cpu01,and connect with a pro27,(all are very old),problem is that:
power off and then turn on ,only power light is on,other all off,the program didn't run,we must press clr and mon to run it.the pro27 show run password.
the normal situation is pro27 show monitor password
nobody change the setup,what is the problem?hardware(cpu or memory card) or software?
i download the manual of the pro27,but the key is not the same with my.
pls help me ,thank you very much.
What position is the key switch in?
Push "Clear", "Monitor", "Clear", than put the key switch into monitor and the program should run.
you say is right,but it was automatic before,now i must deal with it by manual when power restart.why do it not run when the pro27 show run password?
Dear Omron PLC Experts, We just bought a new C200H-IP007. We want to connect it to Omron C200H, CPU01 PLC. But when I connect it to PLC no...
1,508
I have an Omron C200HE-CPU42 PLC with some I/O cards. There is a problem in the C200H-ID212 card. during PLC normall run the PLC gives fatal error...
5,650
hi, I got a problem with c200h plc which is on an old machine. i can not communicate with it using "work online". i try auto online and got a...
3,979
I have a OMRON C200H CPU21 here. I tried to upload the program using CPM1-C1F01 but fail to upload the program. But if I connect to C200HS PLC...
8,359
I have a sysmac omron plc C200H CPU01,only the power led is ON,using CX-ONE programmer software, and connecting to the plc via Host link LK202-V1...
714
