C28K Omron memory error
Gary,
Could not agree more. Since I don't currently have the hardware and software available to me to download the program I have one of my helpers going line by line and documenting the program. It's tedious, but worth it.
Furthermore, I'm working on obtaining the software (syswin) and hardware (host link etc) to download the program and convert it to work with Omron's latest PLC. That way if I lose one, I can replace it with a brand new one.
Again, I can't thank you enough for your help. I've learned quite a bit about these things this week. It's not a common elevator component.
Hi Sam,
Just a heads up. Syswin is also obsolete. It will be able to communicate serial to the Host Link of the 'K' series with a 3G2S6-LK201 unit to save the program.
The new controllers from Omron will probably be the CP1L / CP1H. These require CX-Programmer to communicate to the PLC.
CX-Programmer can upload the older program from the saved Syswin file. You will then need to change the channel allocations in the unit before downloading to the new PLC.
Note: CX-Programmer is part of the CX-ONE package from Omron.
You can download a trial version of CX-ONE for 30 days before you will have to pay for the software.
https://industrial.omron.ca/en/products/cx-one#downloads
Let me know if I can help you out with anything.
Regards,
Hello PLCS.net: I have encountered an Omron C28K that lost it's program due to battery failure. Luckily, I had a backup and was able to re-enter...
3,355
Hello! I'm working in upgrading an old c28k Omron to a cp1e. My doubts are concerning the IO pins. I can see in syswin 3.4 the following inputs...
2,485
When an eprom (ROHM) is plugged into a Omron Sysmac C28K PLC does it automatically load when the unit is powered up?
1,254
Hi All, We have an old machine with an OMRON C28K PLC. Lately, the said machine is unable to run and noticed that the PLC processor's "RUN" LED...
1,937
Hey all, Hopefully I can get some help here; trying to help a friend get a program backed-up on his C28K which, obviously, is quite old. In...
4,304
