Cable for input devices
lthorns
Jun 2018
MI
I'm currently working on a machine and have found that a cable has a short in it somewhere, however it a very long cable and is wrapped in some flexible conduit, and instead of cutting the cable apart and looking for a broken wire or something i thought to replace the entire cable. the cable runs from the PLC directly to a box with the wiring of some prox switches, its basically just a nice little pre twisted and wrapped cable with about 24 wires you can run from your plc to field devices. The part number for the cable is A1221612 and the brand is Lutze however i can't find the cable on their website was wondering if anyone knows of a similar cable that would work for what i'm doing.
Didn't look up your part number. Guessing at specs based on description. Assuming 12 pair control cable. Look at this Belden cable from Mouser to see if it's what you're looking for. Note as paired cable, it will have 12 black wires. All of them should go to 24DC return. If you want 24 colors, then don't search for paired. Just look for Multiconductor "Control" cable.
Edit. Your part number is 16 gauge, 12 conductor. Not 24 conductors. Similar cable from Automation Direct.
Hello guys, I have an issue about maximum cable length calculation of a digital input on Siemens SM321 card. by calculation and according to...
2,938
We are Boiler manufacturer. The boiler are used in steel and other process industries. All our boilers are controlled by PLC with SCADA or by DCS...
2,070
Please I want to know what is cable size (mm)reqiured for digtal input for 250 m cable length? 24 VDC is used
2,123
I am considering using a "magnetic cable tie mount" like this one: https://www.grainger.com/product/MAG-MATE-Magnet-with-Zip-Tie-Holder-49M018 It...
104
I have an existing machine that we are adding some functionality. Currently every cable such as a cable going out to a 4-20 psi sensor for example...
259
