Cable for Sincos encoder
Plc_User
Dec 2005
Belgium
317
We will be using a sincos encoder in a future project and I was wondering if some precautions have to be made towards cabling. For normal incremental encoders 5V TTL 1024imp with a cable lenth of 30 m we use screened cable 0.35 mm2 but the wire pairs are not twisted. I thought that for a sincos encoder the voltage levels of the signal pairs are only 1 volt. Our cable will be 30m long. Should a screened cable with twisted pairs or even seperate screened twisted pairs be necessary? Who has experience in wiring sincos encoders?
Assuming Sinamics (from your previous posts), can you wire the encoder to a local SMC module and then use Drive CliQ for the 30m run ?
We already ordered a sincos encoder without drivecliq and an SMC20. Would you prefer the 30 with drive cliq? Experiencs?
I am considering using a "magnetic cable tie mount" like this one: https://www.grainger.com/product/MAG-MATE-Magnet-with-Zip-Tie-Holder-49M018 It...
101
I have an existing machine that we are adding some functionality. Currently every cable such as a cable going out to a 4-20 psi sensor for example...
249
Hello everybody, I believe that I will find experts here who have already solved a similar topic. I need to calculate the length of the...
352
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
132
Can anyone recommend a universal USB to IrDA cable for interfacing with power meters? I see a lot of generic units but hoping someone has...
64
