Cable needed for Allen Bradley Modem 9300 RADKIT
kemppioy
Oct 2005
Dallas
72
Hey,
I received an Allen Bradley Modem 9300 RADKIT to be used with my SLC503 processor. Unfortunately the serial cable that has 9 pin d connector on both sides is missing. Does anyone have the cable pinout for that? Is it a standard straight serial cable or is it null modem? There is a null modem adapter with the kit. Can I just use the straight serial cable with null modem adapter if that is needed? Where can I find the pinouts of the cable. I don't want to use the cable that has the end that connects to the programming port. I need the one that has serial D 9 pin connections for both modem and plc channel 0.
Paul Kemp
If you just purchased this, and it didn't contain all of the items listed below, I would return it to my distributor. The cable pinput is in this link:
http://domino.automation.rockwell.com/applications/kb/RAKB.nsf/0/B12B70CDA6741ABD8525707C00501614?OpenDocument
9300-RADKIT
1- 9300-9MRT9FRT (CLX, SLC cable – 5ft.)
2- 1761-CBL-PM02 ser. C (MicroLogix Serial Cable – 6ft.)
3- 9300-9M9MNULL (Male to Male 9 pin Null Modem Adapter)
4- 9300-25M9MADAPTER (PLC Adapter)
5- 9300-RADM1/B (Series B Modem)
6- Power Supply (110vac to 12vdc, 600mA)
7- Phone Line Cable (7ft.)
8- Tutorial CD (9300-RADCD1)
9- Quick Start Guide
Hi all, A client has an existing pump house with a GE 90-30 PLC controlling things. I need to connect to it and extract the code and tags from...
2,532
Well, Bubba struck again, I am part of the IT department and we do all the plc programming. I will also add that all but 1 on the IT department...
1,700
We are trying to use 1492-AIFM8S-3 module with 1756-IF8I module. RA has a technical post "728767 - Wiring system solutions for 1756-IF8I...
1,273
Does anyone know the correct AB cable I need to connect a laptop serial port to an SLC 5/04 processor programming port, specifically the DIN...
13,316
Completed alot of .pdf's, Still unsure what direction to proceed. Want to use SLC/5/03 OS302 B Rev10.Channel-0 [DH485] [9-Pin] to SP10 Com-2 RS485...
4,793
