Cable numbering
Chewy1980
Mar 2018
Collaroy
Hi guys,
First post from a relatively new programmer. I am building a control system for a client and they have no specific wire numbering request. Is it best practice to use the rack and slot numbers as the cable designation?
I would normally use page, column, sequence to number wires etc.
just wondering if there is a standard or best practice? I’m in Australia.
Cheers chewy1980
Just whatever you do try and keep it the same, once your customer learns your method then its will be good for them but if you change it makes it a pain
We bought several machines from one builder and on the 3rd they changed the color code o_O
I have seen some rather elaborate methods to identify/lable wires and devices that seem very useful, until something gets changed or added in the program and/or the schematic.
Then nothing matches. Choose a system that can work with future expansions.
1 through 9001. Look at the drawing if you want to know what the wire does.
This is what we do.
200 group Plc inputs
300 group PLC outputs
400 group analog in etc....
Page one the designations and last number used.
this works for most of our jobs
It massaged for jobs with a lot of OI
there are a thousand ways to number just keep it consistent.
do not get to fancy, nothing worse than long wire number (in my opinion)
Hey thank you everyone for your input. Awesome platform to learn. I have come up with a basic wire management system that our customer has approved so we have a place to start.
Thanks again guys much appreciated.
Chewy
+1 for this from the Bubba side of things. As long as it is consistent, I'll figure out what you are up to.
Bubba.
I have an existing machine that we are adding some functionality. Currently every cable such as a cable going out to a 4-20 psi sensor for example...
249
I am considering using a "magnetic cable tie mount" like this one: https://www.grainger.com/product/MAG-MATE-Magnet-with-Zip-Tie-Holder-49M018 It...
101
Hello everybody, I believe that I will find experts here who have already solved a similar topic. I need to calculate the length of the...
351
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
132
Can anyone recommend a universal USB to IrDA cable for interfacing with power meters? I see a lot of generic units but hoping someone has...
64
