Cable Pinout Database
steves0118
May 2012
Iowa
I am looking for a cable pinout database. I found several references to www.rj485.com in old posts, but the website is down. I also found some references to www.allpinouts.org, but I cannot create an account to add new diagrams. The only active database that I found is www.pinouts.ru, but they don't have much for PLC cables.
Does anyone know of a PLC oriented active online pinout database that I can contribute to?
I'm not sure what you are looking for but I have a few to donate if you are looking to start one for multiple PLC platforms.
Most of mine are GE related though.
I suggest starting one on Wikipedia or github!
Possibly github, as it could be extend to have CAD exports!
Let me know if someone is keen on starting a github for pinouts.
I like the idea of using a Wiki, which is what AllPinouts.org is based on, but I don't want to reinvent the wheel. First I want to check if there is an existing database that I can use and contribute to.
Thanks for everyone's input. I will check on a couple other forums to see if I can find an active database. If I come up with anything I will post a followup.
Anyone happen to know the pinout on the RJ12 side of a GE HHM cable? It's just a serial 3-wire and I know the DB-9 side. Thanks.
1,088
I need to emergency fabricate a cable to program a Parker 690+ VFD. Part # CM351909 I believe. RJ6 on one end, DB9 on the other. I cannot find the...
2,314
Gents - hope somebody can help out, I've been tasked with fixing an OLD SCADA system. I've got an S7-226 PLC thats configured for Modbus comms via...
1,464
Hi, I know this is not a PLC issue, sorry. I have a Sick Safety Laser Scanner and I wanna get connected to check some issues on it. I do not...
2,728
Does anyone have a wiring pinout for an NES series drive programming cable? I have a usb to serial adapter so I just need a pinout for the rj45 to...
1,460
