GE HHM cable pinout?
timothy585
Supporting Member
Apr 2021
Cajun Country
47
Anyone happen to know the pinout on the RJ12 side of a GE HHM cable?
It's just a serial 3-wire and I know the DB-9 side.
Thanks.
Looking at the end of the RJ11 connector that plugs into the HHM with the locking tab facing down, the pin on the right connects to pin 5 on the DB9. The next pin to the left connects to pin 9 on the DB9. The next three have no connection. The pin furthest left connects to pin 4 on the DB9.
Awesome.
Thanks!
Hi: I am sitting here with a GE Fanuc Genius remote input base and electronic block. I have the handheld programmer (HHM). I need to set the bus...
2,507
My first PLC was a Modicon 584 back in the late 80's. Ladder logic was no problem to utilize. I built a pc pased hmi on a 386 using fortran and...
2,253
I am considering using a "magnetic cable tie mount" like this one: https://www.grainger.com/product/MAG-MATE-Magnet-with-Zip-Tie-Holder-49M018 It...
92
I have an existing machine that we are adding some functionality. Currently every cable such as a cable going out to a 4-20 psi sensor for example...
238
Hello everybody, I believe that I will find experts here who have already solved a similar topic. I need to calculate the length of the...
348
