Cam controller FM352 help please
kevbloke
Jul 2004
Kent uk
81
Hello,
I have an Alfa quatro bottle labeller which is being a bit grumpy at the mo.
There is a blade on drum that rotates and this in conjunction with a stationary blade cuts a length of label which is then applied to a bottle.
The drum is controlled by an encoder whish is connected to a FM 353 cam controller.(PLC 315/2DP)
When the operator sets up the label he has to input length, window of operation and cam zero point.
He aligns the blades, presses "zero cam" and this tells the cam controller the zero point.
This machine is normally very well behaved but at the mo it's stopping occasionally saying "cam needs zeroing".
This is normally only the case if there is a change of label or length deviation.
I have checked the encoder and all seems ok through 360 degrees.
If the output m8.0 goes high, the cam needs re zeroing. I have posted a screen shot of the program and i wondered if someone could shed some light as to how m8.0 is generated please.
Kev
Only the obvious springs to mind: The encoder is momentarily loosing its supply or the encoder is faulty. Is it getting progressively worse? Is the encoder belt driven. I had one fail. Without belt tension, it worked perfectly, but with the belt on - it stopped counting!
Hey Guys, need help comparing Siemens FM 352 cam controller with S7-1500 input and output cards. - Do i look for the input/output speeds ?? -...
2,171
Can anybody provide me manual instruction of "WF707 CAM CONTROLLER" ?
1,607
Hello everyone, I have a machine with a mechanical cam on a rotating shaft that ativates a prox sensor to turn a spray gun on and off with...
2,882
Hello all, I'm looking for ideas or solutions on having a industrial webcam or IP camera that we could use on our equipment to help monitor and...
1,219
Kindly, I was trying to use the Motion Arm Output Cam (MAOC) instruction on a Rockwell plc, but I need to have it in a general AOI function. So, I...
1,038
